How to test for a bad fuel injector?
Old Nov 3, 2003 | 02:12 PM
tryme96Z's Avatar
As topic states. Need to test for a bad fuel injector.
Old Nov 3, 2003 | 02:51 PM
Type_O_Negative_1320's Avatar
Unplug each injector (one at a time) with the engine running and check for a difference in idle. If idle does not change when you unplug one, that injector is not working. Make sure that you check the wire going to that cylinder also (if you find a bad one).
AdsoYo
May 2, 2018 03:21 AM
Jul 4, 2005 05:00 PM
naaz90
Jul 27, 2002 08:22 AM
