How to tell when Posi is on it's way out.
Old May 9, 2004 | 10:12 AM
TrooperZ28's Avatar
For some reason, I feel that my rear end is going out on me. I think the clutches are worn. The car isn't gripping as well as it should but the tires are fine. Not only that, in my "test" to check it, I'm only getting one line of rubber intermittantly. I'm probably going to pull the diff this weekend to see what's up.
The posi is stock, if I need to rebuild it, what kind should I go with?
Old May 9, 2004 | 10:21 AM
Like My Taillights?'s Avatar
SLP sells stock take out units for around $95. The dealer wanted $400+ for it. I paid $100 to get it installed and it works great.
-Rob
Old May 9, 2004 | 12:34 PM
SS MPSTR's Avatar
Re: How to tell when Posi is on it's way out.
Yep, that's the sign it is going. When I had my 10-bolt, I replaced the posi with an Eaton unit, which is about $370. Worked great until I broke the ring gear, then I stepped up to the 12-bolt.
Old May 9, 2004 | 12:35 PM
ChickenScreamer94's Avatar
change the fluid and put in teh GM (and only GM brand) limited slip additive. THis cured my one wheel peel and funky grinding around turns too. It was about 15 bucks including the gear lube and gasket
Old May 9, 2004 | 01:21 PM
1msfyter's Avatar
My stock auburn bit the dust last monday. Going with an Eaton HD, all new bearings, C clip removal/reto fit.
http://www.fasterbaby.com/under2.JPG
Old May 9, 2004 | 08:08 PM
TrooperZ28's Avatar
Sweet, thanks guys. I was looking at the Auburn style before. Like I said, I'll proabably be ripping it down this weed sometime.
Old May 9, 2004 | 08:14 PM
ABA383's Avatar
If you go with Auburn make sure you get the Pro series....HUGE difference...
Old May 9, 2004 | 08:15 PM
TrooperZ28's Avatar
Raajo!
Old Jul 27, 2004 | 01:21 AM
tomatocity's Avatar
This sounds like what my rearend is doing. What differential fluid did you use and how many pints would I need?
Old Jul 28, 2004 | 11:45 AM
bozobuttz's Avatar
-Rob
I'm not seeing the "take off" posi's on the SLP website. Do you have a link for it?
Old Jul 28, 2004 | 12:07 PM
LWillmann's Avatar
I believe you can test the clutches by lifting one rear wheel and checking the torque it takes to turn the wheel. I'm not sure of the reading you should get though.
My car will one-wheel it now and then depending on conditions, it's not always the same wheel either.
colts0455
Oct 4, 2015 09:47 PM
Sep 18, 2015 03:46 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
