How to tell if you are getting Knock retard?
Old Sep 13, 2005 | 05:49 PM
Jazsun's Avatar
I recently put on LT4 springs and GMPP 1.6 RR's. I have stock manifolds w/ magnaflow catback. Do you think it would pull timing because of the RR's? I raced my car today and It seemed like it didnt pull hard at all uptop, but maby its in my head which is very likely. What type of thing do you use to detect KR from the PCM? (take into mind I am a 93). I am thinking of doing the KM desentizer using the resistors soon, but dont know ifi ts really retarding timing?
Old Sep 13, 2005 | 05:58 PM
Jameslt1TA's Avatar
Re: How to tell if you are getting Knock retard?
Not sure if you can do it with a 93 or not but i bought a cable and downloaded free scan it will tell how much kr your getting.
Old Sep 13, 2005 | 05:59 PM
Z95m6's Avatar
I usually just look at my laptop.
Old Sep 13, 2005 | 06:04 PM
OBE1 95Z28's Avatar
You need a scan tool that's compatable with 1993's, not sure if Diacom or scanmaster works.
Are you sure you set the correct valve lash when you replaced your RR's?
Old Sep 13, 2005 | 06:05 PM
Kurt Crosbie's Avatar
What is the point of buying an all-out scanner as opposed to buying a laptop? What is more effective?
Old Sep 13, 2005 | 06:16 PM
Jazsun's Avatar
Im pretty sure, I did a little more then 1/2 turn after reaching lash.I can definetly hear them when driving next to a wall so I doubt they are too tight, and loosing compresion. Which is what you are getting at right?
Old Sep 13, 2005 | 06:26 PM
Jazsun's Avatar
Also, I have a a laptop to use, so its just a matter of getting a cable which will read ffrom my OBD1 port and loading up a program on the laptop?
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
asilomar244
Jul 12, 2015 05:53 AM
