how to tell...
Old Aug 26, 2008 | 12:04 AM
Blacksmith's Avatar
Question how to tell...
for the LT1 owners out there, how do you tell if you spun a bearing
Old Aug 26, 2008 | 12:36 AM
SS RRR's Avatar
Lower than normal oil pressure is the most tell tale sign. You can also drain your oil, run your fingers through the oil while it's draining to see if you can feel and see metal flakes as well as cutting open the oil filter.
Why do you ask?
Old Aug 26, 2008 | 12:44 AM
mrmint69's Avatar
Makes a very unusual noise coming from the bottom of the engine. If you hear a video of someone who has one, its pretty obivious.
Old Aug 26, 2008 | 01:11 AM
ACE1252's Avatar
Mustang with a spun rod bearing.....
http://www.youtube.com/watch?v=q8qb0ur4e8A
LS1 with a spun bearing.....
http://www.n2s1.net/RacingVideos/havoc_enginesound.wmv
Old Aug 26, 2008 | 01:48 AM
bombebomb's Avatar
little to no oil pressure at idle, very odd sounds coming from the motor.
Old Aug 26, 2008 | 07:41 AM
DAVE00's Avatar
When I spun mine bout 10 years ago, got a loud ticking noise and oil pressure went to 0.
Old Aug 26, 2008 | 09:11 AM
I spun a rod bearing with no apparent effect on oil pressure. The noise is the best indicator.
Brangeta
Jul 21, 2007 12:12 PM
danhr
Jul 9, 2007 04:59 AM
Klypto
Nov 9, 2006 03:31 AM
Klypto
Aug 19, 2005 02:28 PM
