How to take apart alternator?
Old Oct 16, 2004 | 03:56 AM
jonota's Avatar
I'm stuck trying to remove the pulley from the alternator. Can anyone who has done this give a little guidance?
Jonota
Old Oct 16, 2004 | 03:58 AM
'97SLVRBullet's Avatar
Re: How to take apart alternator?
pulley puller?
Old Oct 16, 2004 | 08:59 AM
n2ceptor's Avatar
Once you remove the nut, you can remove the pulley... If its stuck, get a pulley puller...
Old Oct 16, 2004 | 09:48 AM
Mtrhds94Z's Avatar
The nut is the hard part.. use air impact..
Or I one time used the allen wrench hole in the center and got a cheap socket that fit the nut and ground 2 flats in it... [that way you can put an allen wrench in the hole of the socket]
pipe wrench on the flats, smaller pipe on the allen wrench.. PB Blaster on the threads..
after some fighting with it it came off.. it's TIGHT tho..
Impact probably best tho maybe take it to a shop for just that process if you don't have one?
Old Oct 16, 2004 | 04:50 PM
jonota's Avatar
Thanks for the input guys!
Jonota
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
Thirim
Jul 30, 2015 01:29 PM
