how to set valve lash without hub installed
Old Dec 2, 2011 | 03:58 PM
vincent714028's Avatar
I've disassembled my engine to replace various seals and want to adjust valve lash while I'm in there but I don't know when to adjust the valve since I can't determine where TDC is per cylinder. I've already removed the hub. Does anyone have an idea?
Old Dec 2, 2011 | 04:06 PM
RamAir95TA's Avatar
Re: how to set valve lash without hub installed
www.shbox.com has a thorough how-to procedure. Whether you use the hub or not it doesn't matter. Just stick a proper 7/16x20 bolt in the crank and turn.
Old Dec 2, 2011 | 04:32 PM
Method #3 http://shbox.com/1/4th_gen_tech2.html#adjust_valves .
HectorM52
Jul 30, 2017 11:46 AM
Roadie
Feb 16, 2015 10:34 AM
Chevyguy358
Jan 28, 2015 08:04 PM
thenewkid
Nov 29, 2014 04:54 PM
