How to route my wires?
Old Sep 14, 2003 | 09:20 PM
rob96TA's Avatar
I got a set of taylor custom fit wires, and i was wondering if the have to run in the stock route or can they be used to travel over the valve covers and away from a set of headers? Passenger side esspecially, cause the factory route is from behind the power steering pump. Thanks
Old Sep 14, 2003 | 11:31 PM
revtime's Avatar
Custom fits should be long enough to let you do just about any routing you want (within reason) so yes over the valve cover should be possible.
I used a set of premade MSD superconductors and I routed them basically stock and I have no problems.
You can go through the bracket on the passenger side, I have mine routed through the bracket, I just put some convoluted tubing over the wires to protect them from rubbing.
Nov 18, 2023 07:21 PM
thenewkid
Apr 12, 2015 07:42 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
