How to remove injectors from fuel rail??
Old Jan 1, 2004 | 05:41 PM
Brandon 95 Z28's Avatar
Question How to remove injectors from fuel rail??
Hey,
I have the fuel rail off, and want to install my SVO 30# ers, and was wondering if there is any trick to removing/installing the injectors from the fuel rail. I played with them a little bit, and it looks like they are just held in by that little clip, do they just push out the side of the clip where the hole is??
Thanks,
Brandon
Old Jan 1, 2004 | 08:14 PM
95BlackTA's Avatar
How do your get the fuel rail off. Dont you need some special tool?
Old Jan 1, 2004 | 08:20 PM
AsianSensation's Avatar
You will need a fuel disconnect tool and remove 4 bolts securing the fuel rail down. Just pull it up.
Old Jan 1, 2004 | 08:28 PM
VeryBad's Avatar
Here's a link that I put up on a 95 Vette, it has the info you need.
Injector removal
Gordon
WitchHunter performance
Old Jan 1, 2004 | 08:47 PM
Cool, looks pretty easy. Thanks for the replies.
Brandon
HectorM52
Jul 30, 2017 11:46 AM
LT14LIFE
Feb 9, 2015 09:35 PM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
