How to remove the dipstick...
Old May 26, 2004 | 04:47 PM
Myxtreme1's Avatar
Do I have to remove the starter to get the oil dipstick out?
Old May 26, 2004 | 06:00 PM
Spinner's Avatar
No. There's a bolt on a very small bracket that's part of the dipstick. Remove bolt, and twist/tug. It'll come out eventually
Old May 26, 2004 | 06:58 PM
94zLT1's Avatar
grab a clamp wrench..clamp it...twist and push stick upwards from bottom of car while some is pulling on it from the top (no too hard it will collapse)...after a little movement you will see the "lip" that sealed it into the pan...grab a flathead screwdriver and hammer and put the screwdriver on the lip and hammer the screwdriver up...it takes some time but DONT collapse or crush the dipstick and use a person pulling from the top throughout all of this..have fun
Old May 26, 2004 | 07:06 PM
My dipstick has a ring on the end of it. I just pull it out. <shrug>
The dipstick tube is another story.
Dave Feerst's Avatar
take out bult. pull/ wiggle. It does help to have a person tap on the bracket from below...
Old May 26, 2004 | 07:39 PM
ibanez6rg's Avatar
To remove my tube it took two people to get it out. Second time I took it out it broke.
Old May 26, 2004 | 07:46 PM
Nestromo's Avatar
After I installed my headers it was impossible to get back in in one piece so I cut it below the bracket and spliced it with heavy duty rubber hose and 2 hose clamps. I also had to bend it a little bit to get it to fit with the way the new primaries were.
Old May 26, 2004 | 08:21 PM
AdamZ1LE28's Avatar
I'm putting in Pacesetters soon. Do I need to remove the dipstick??
Old May 26, 2004 | 09:25 PM
Myxtreme1's Avatar
Ha ha. I got it off. Thanks guys.
Old May 26, 2004 | 10:25 PM
SLeePer350's Avatar
i'd like to know as well, everyone says these headers do not require notching of the k-member, etc. - however they do not mention the dipstick, i heard its a real PITA trying to work around that thing
Old May 26, 2004 | 10:38 PM
ibanez6rg's Avatar
I had to remove mine for my LT install.
Old May 26, 2004 | 10:45 PM
95_LT1_6SPD's Avatar
You will have to remove the dipstick. I cant remember but dont you have to remove it to get the old ones out? Either way, its a 5 minute job.
Old May 26, 2004 | 11:01 PM
Nestromo's Avatar
If you aren't gonna do headers just because you will have to remove the dipstick... then you don't want an LT1.
Old May 27, 2004 | 04:29 AM
Myxtreme1's Avatar
With the starter and dipstick TUBE (lol) outta the way and the car jacked up that side is a cinch for header install. Small amount of work for power .
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
