How to remove the dipstick...
grab a clamp wrench..clamp it...twist and push stick upwards from bottom of car while some is pulling on it from the top (no too hard it will collapse)...after a little movement you will see the "lip" that sealed it into the pan...grab a flathead screwdriver and hammer and put the screwdriver on the lip and hammer the screwdriver up...it takes some time but DONT collapse or crush the dipstick and use a person pulling from the top throughout all of this..have fun
After I installed my headers it was impossible to get back in in one piece so I cut it below the bracket and spliced it with heavy duty rubber hose and 2 hose clamps. I also had to bend it a little bit to get it to fit with the way the new primaries were.
Originally posted by AdamZ1LE28
I'm putting in Pacesetters soon. Do I need to remove the dipstick??
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
