how often should you adjust the rockers?
Old Nov 12, 2007 | 08:00 AM
Critter's Avatar
i have crane gold 1.6 rr's on my car and i just realized i havn't adjusted them since i redid the engine! i have put about 5k on the motor since then. how frequent do i need to do this?
Old Nov 12, 2007 | 08:33 AM
wrd1972's Avatar
I would check the rocker geometry right now at the least with 5K to make sure all is well. Look for the sweep pattern on the valve stem tops on at least 2 cylinders. After that if you dont have abnormal sounds or excess ticking you should be good.
Old Nov 12, 2007 | 06:00 PM
96capricemgr's Avatar
Hydraulic roller with all in proper working order should need no adjustment.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
Slayer
Aug 17, 2015 03:55 PM
realistyc
Jul 28, 2015 07:32 PM
JCSWS6
Jul 19, 2015 06:47 PM
