how often do you guys adjust your NSA rockers?
i want to make sure i keep up on these things. i've been so paranoid the last couple days that i'm actually hearing phantom rocker clicks with everything that makes noise on my car. i had one get loose on me a week ago just after i got it all back together. i got them all back on right and adjusted them with the engine running and tightened the poly locks really tight. how often do you guys pull the covers to adjust them, if at all? basically, are these things maintenance free unless you hear one making noise or should i do regular check ups on them?
btw- i have the 1.6 pro mags.
Re: how often do you guys adjust your NSA rockers?
Originally Posted by shoebox
Let's see...put the motor together 14 months ago...haven't touched them since.
Daily driven.
Daily driven.
<<did my 1.7s on December... went back once to readjust them only cause I over tighten them...
No need to be messing with them and they actually got so much quieter now after a few hundred miles.
marvin
marvin
