how often to change oxygen sensors?
Old Jul 12, 2007 | 03:13 AM
Camaro1996's Avatar
hey guys i was wondering how often you change your ox sensors? my car has 95k miles and is running poorly, hesitating and stuff. im wondering if the sensors may be going bad...
Old Jul 12, 2007 | 03:35 AM
mrmint69's Avatar
now would be a good time. Maybe 60-80K miles would be about right.
Old Jul 12, 2007 | 07:16 AM
BassProCamaro97's Avatar
Might not be a bad idea to change them. Hpwever, I can't say guarantee It'll solve your problem. Do a search and you'll see plenty of people have had hesitations and have had a tough time tracking them down.
If you know any one with a scanner start there then start with parts. Hate to see you waste your money and not have the problem solved.
When my O2 went out it through a code.
~Jim~
Old Jul 12, 2007 | 07:26 AM
JP95ZM6's Avatar
I just replaced mine at 84k after breakin of new engine, hoping to improve a high rpm missfire. Didn't fix that, but idle got less stinky, BLMs got better. Old O2 sensors would still swing from 100 - 900 mV or so, but faster and not together. New ones swing slower, and much closer to matching. Split BLM's got better for most cells, but still see differences up to 20 in some cells, with about 20 miles on PCM reset.
Old Jul 12, 2007 | 12:31 PM
Camaro1996's Avatar
What are BLMs? Also, are oxygen sensors supposed to not swing readings back and forth so fast?
Old Jul 12, 2007 | 02:20 PM
mrmint69's Avatar
On a scanner it will go from 100-900 very fast once the car wams up. So fast it hard to tell what number its on. Maybe 2 changes a second. Read this:
http://members.aol.com/InjuneerZZ/ScanMast.htm[/URL]
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
captcorvette
Mar 7, 2015 12:37 PM
eazyZ
Mar 1, 2015 07:12 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 8, 2002 12:36 AM
