how to needed: changing fuel filter
Old Feb 9, 2004 | 06:39 PM
pvkn1ght's Avatar
Question how to needed: changing fuel filter
anyone with a spare moment:
Can someone give a step-by-step on changing the stock fuel filter on a 95 TA? (i.e. fuel-filters for dummies)
havn't found any written yet...
THANKS. Brian
Old Feb 9, 2004 | 06:45 PM
blazzinbird's Avatar
pretty simple
her eis what i did
pull the fuse for the fuel pump, start the car so ther eis no fuel in the lines, remove gas cap
put the car in the air, just loosen one side with a open end wrench, and the other is just snaped in. took me maybe 20 mins, taking my time
remember do not smoke a cig while doing this
Old Feb 9, 2004 | 06:51 PM
ChevyIron's Avatar
Also have a container or rags underneath the filter cause there will be some fuel that leaks out when you take the filter apart.Watch your eyes to that feul does a #.
Old Feb 9, 2004 | 07:14 PM
Spinner's Avatar
Pop the nut off, pull the filter out. Put the new one on. Takes 2 minutes once the car's in the air.
Old Feb 9, 2004 | 07:22 PM
atljar's Avatar
They all said it pretty well. Either pull the pump fuse, or unplug it and let it the car run til it dies. That will relieve your fuel pressue.
You can also relieve it on the shraeder valve on the back of the intake manifold and bleed it off from there.
Remove gas tank cap to relieve tank pressure.
Get the rear of the car in the air, and swap the filter. One side is held with a clip, the other a nut. Fuel will spill out. Put in new filter. The filter itself is underneath where the rear passenger would sit. Good idea to spray the nuts with some rust eater, WD 40, liquid wrench etc and let it sit for a bit since the nut will likely be pretty rusted before attempting to take off old filter.
Before you start you car, plug in pump or fuse. Turn key to run, but dont start. Key off. Repeat the key on, no start, key off 5 or 6 times. That should prime the system and get your pressure back. Get under car, make sure its not leaking. If no leaks, go ahead and start it up!
Old Feb 9, 2004 | 08:36 PM
Brand new help. Virtually what was already said.
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
