How much would tune help?
Old Apr 6, 2006 | 08:42 PM
slow95camaroz28's Avatar
I have CAI, jet hot long tubes, high flow cat, no muffler, hypertech. Will I gain much off of it and if so what should I expect? Also what should me et be around and how much will 4.10s help?
Old Apr 6, 2006 | 08:52 PM
ibanez6rg's Avatar
Re: How much would tune help?
A dyno tune is always beneficial. With your mods, you really don't need a tune though.
Old Apr 6, 2006 | 10:25 PM
Ray86IROC's Avatar
I've got basically the same mods, albeit with edelbrock midlengths. Anyway, I just got the Madz28 email tune last week, on the first baseline revision right now (waiting on new tune if needed after some datalog runs I sent in). Anyway, as soon as I flashed the custom tune and started the car I could feel a difference, everything about the car was just smoother even at idle, I added a 160 stat at the same time and w/ his fan adjustments the thing runs perfectly cool, so far has not even gotten a hair over the 180ish mark on the gauge. Car feels a little stronger at WOT but power gains are hard to say without a dyno run obviously.
For people w/ headers and such still on the stock tune I'm going to be strongly recommending a madz28 or similar tune now. Previously I didn't really think I would benefit that much from it, but I'm very happy w/ the results so far. But you do have a hypertech already. Now although everyone will slam the Hypertech, I wonder how much you'd really gain over it w/ a custom mailorder tune with these levels of mods. Seeing as you can probably go back to stock and then sell the Hypertech on ebay or something for the cost of a mail order tune I'd say you'd be better doing that, but who knows how much power you'll really gain. If you get a actual dyno tune I'm sure you'd pick up some, and you'll know you've got an excellent tune for your particular car...
Old Apr 6, 2006 | 10:36 PM
GT KILLER's Avatar
Well, I'm getting a HPPIII after my gear change and T-stat change.......people bash it, but I'm not exactly in need of a full tune....I'm not nearly going to have enough mods to warrant that. I'm getting the programmer to make the necessary changes after my mods......I'm not tuning for cam/heads or nitrous.
Old Apr 7, 2006 | 04:41 AM
2000GTP's Avatar
What kind of tune are you referring to... a dynotune, a mail-order tune, or a Hypertech tune? A dynotune would not be worth it for your mods. and a Hypertech programmer is a waste of three hundred bucks in my opinion. A mail-order tune from Madz28 or Pcms4less would probably be your best bang for the buck. I think they say gains of 10-15rwhp is common, but they also tweak alot of other things like coolant on/off temps, tranny shift firmness, gear changes, SES code removals,ect.
Old Apr 7, 2006 | 06:43 AM
JAFO1994's Avatar
I would never consider even buying a hypertech, unless I got it cheap and needed to adjust for gear changes. Get a laptop and program or have someone who can for you. I run a 13.3 without juice with just shorties, cia, catback, and programming. Not only gives you gains, but you can make the car alot more fun, especially if you have an auto.
Old Apr 7, 2006 | 11:38 PM
I was thinking of a dyno tune.
Aug 24, 2015 06:41 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Shookiez28
Jul 23, 2015 01:55 PM
