How much will factory bottom end hold?
Old Feb 13, 2007 | 02:50 PM
69gto96z's Avatar
I am rebuilding the bottom end of my LT1 this summer, i plan to just pull it apart, re-hone the cylinder walls, install some clevite bearings, new rings, and probably polish the crank. I plan on putting on a LE2 set-up and will continue to spray a 100 shot. Do you think it will stay together?
Old Feb 13, 2007 | 02:56 PM
hotrod18_69's Avatar
If your gonna rebuilt it you might was well spend alittle extra for insurance.
Forged Rods and fairly cheap
http://www.cnc-motorsports.com/produ...22&CtgID=21452
Throw in a set of good forged pistons..
http://www.cnc-motorsports.com/produ...71&CtgID=16042
And go have fun!
Old Feb 13, 2007 | 02:59 PM
speed_demon24's Avatar
Back when I had nitrous I was makin over 500rwhp on a stock 96k bottom end, then I thought better of it and took it off.
Old Feb 13, 2007 | 03:04 PM
BUBBA's Avatar
Splayed mains might be nice if affordable.JMHO
Old Feb 13, 2007 | 03:34 PM
Nice yes, but not needed for what he's doing..
Old Feb 13, 2007 | 03:45 PM
69gto96z's Avatar
Yeah I wouldnt mind it, but this is a budget build while im in college.
Old Feb 13, 2007 | 05:01 PM
slo_z28's Avatar
I put multiple 10 lb. bottles through my car. never spraying below a 100 shot, and up to a 200 shot on the stock block with over 100k. Never any problems!
Old Feb 13, 2007 | 10:54 PM
Joe B's Avatar
If you make sure to over engineer the Nitrous kit... meaning, have ALL the failsafes in place so that it NEVER goes lean, and so that you cant ever (by mistake) spray it at too low of an RPM... it "should" hold for a long time........Iv'e been running a 190 shot of nitrous (at the crank) since august of 98 on the stock bottom end(lost count of how many bottle refills)......and for the last year and a few months I've been running a 125 Rear wheel HP shot of nitrous on top of the LE2 mods in my signiture......all is still well (knock on wood ).......Cylinder leakdown test was recently done and is still pretty much the same as when the car was new...and the cylinder pressure is still nice and even........good luck with yours..........Joe
Old Feb 13, 2007 | 11:07 PM
69gto96z's Avatar
Joe, that is good to know. I do have all the safety features. I have a fuel pressure switch, a mallory 685 box with timing retard and a window switch. Cant think of anything else I would need.
Old Feb 14, 2007 | 09:07 AM
Joe B's Avatar
Yeah, you should be good to go ...... (if you havent already)...run colder plugs to get even further away from detonation.....After trying nearly everything out there, I like the Autolite 103's ......Joe
Old Feb 14, 2007 | 02:43 PM
69gto96z's Avatar
Yeah, I forgot to put that on there, I am running TR6's.
Old Feb 14, 2007 | 03:15 PM
jsetzer's Avatar
If its going to see any n20 I suggest springing for at least a cheap forged piston. A ping or two on spray and some hyper pistons will fall apart.
I know any suggestions that add several hunder dollars are hard, but your biggest single cost will be the machine shop anyways. Why spend a grand to put a stock motor back together?
Old Feb 14, 2007 | 05:19 PM
69gto96z's Avatar
There wont be any shop work involved except maybe magnafluxing the block. I can do it all myself. That is why I was trying to just stay stock on the bottom end so I didnt have to get it re-balanced.
Old Feb 15, 2007 | 08:55 AM
Z-RATED94's Avatar
Don't forget to use some ARP bolts for the mains and rods. That should help a little.
Old Feb 15, 2007 | 08:57 AM
buzz12586's Avatar
And the heads.
