How much water?
Old Mar 18, 2003 | 07:13 PM
blkn'silver94's Avatar
How much water?
How much water do you guys usually run in your lt1? Do you guys just use nothing but coolant?...thanks Tony
Old Mar 18, 2003 | 07:36 PM
chesee48's Avatar
I thought the bottles that are already pre-mixed are 50/50? Just buy the pre-mixed coolant. But from my knowledge, it should be at least 70/30 mixture. I could be wrong, but thats my understanding.
Old Mar 18, 2003 | 07:46 PM
Bastardcat's Avatar
It depends on your climate. Being from Texas I think you're safe putting more water than coolant--like a 60/40 mix. I typically go 50/50 just because the weather here varies so much. Remember to use distilled water rather than tap water.
Old Mar 18, 2003 | 11:49 PM
whats the difference between tap and distilled(concering using it for the radiator)?....thanks Tony
Old Mar 19, 2003 | 12:53 AM
z28Power's Avatar
I believe that the additional minerals and deposits found in ordinary tap water, while approved for our bodily consumption, can be harmful to a coolant system on the LT1, corrosive and such.
Old Mar 19, 2003 | 12:56 AM
chesee48's Avatar
Distilled can be pre-brought at your local grocery store. .89 a gallon or around there. I've worked in grocery stores all my life
Why dont u buy the pre-mixed coolant? Cheaper and easier in my book then to do it the hard way
Old Mar 19, 2003 | 11:19 AM
will do then..thanks Tony
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Sep 27, 2015 01:07 PM
