How much time will I pick up by dropping weight?
11's even with a single plane intake?
I figured I could go 11's with a stock intake. The cam will be as radical as possible. Whatever will match the heads.
Btw, I see that an LE3 package puts down about 440rwhp at best with a stock intake. I was taught that the single plane would pick me up about 80hp.
What is the ultimate goal? Dyno results with poor track numbers or decent dyno numbers with outstanding track results. there is a difference and you have to decide what your goal is.
they said 80 hp?? I really doubt that much..however, I'm sure you'd make at least 15-20 depending upon the cam. if its a solid roller 25x/26x on a 108 or 110 lsa, then you should hit a high 10 i suppose on a perfect day. my car is totally gutted with 1 seat and no radio, hvac, etc. and i drive it every day with header bullets...people line up for a ride at the grocery store even.
lol you dont think it makes it any less of a "street" car though? To me a gutted car just reminds me too much of a racecar ... I mean, they have thier place, especially in street/strip applications, but for a mostly street car, I wouldnt do it. At least not with a convertible, their already heavy enough.
<<<would love to go 11's with bolt on's.....
wat do u guys think i will run with a CAI, open longtubes, DR's, and about 100lbs weight reduction?..... also what are the cheapest bolt on's that i should do to hit high 12's?....cuz thats my goal.....
Whether you run a 10.9, 11.9 or 12.9 with that setup will depend more on the suspension of the car and your driving skill, but a heads/cam 383 with a single plane has the potential to skim a 10 or net a low 11 with the right conditions.
With those cubes/heads, a single plane isnt going to free up 80hp, it may score you 10-20 peak. But it will let you keep revving and have a more useful powerband.
As far as weight reduction goes, I have pulled a lot of little unneeded stuff (remeber a lot of little things add up) from my car and it is very much still a street car with stock rims/tires, AC, PS, 10 speaker stereo, all crash supports, airbags, stock carpet and interior, and it has a raceweight of 3490 with a 200+ # driver and 3/4 tank of gas. I was PMing with Shon about this last week and hope to pull a lot more weight (another 200# or more) out next season to get deeper into the 12's...
i have a similar setup to what you ared going to rund and my times are in my sig. the car is still on a base tune and stock fuel pump
the car is full weight leather, t-top, ac, with heavy wheels and trapped very well just no traction. After my suspension and 12 bolt this winter i am shooting for high 10s
Scott
the car is full weight leather, t-top, ac, with heavy wheels and trapped very well just no traction. After my suspension and 12 bolt this winter i am shooting for high 10sScott
9...!ABS
21.5!AC compressor
8.5.!AC condenser
....!AC fan motor
13.5!Airbag and bracket, passenger's
4...!Airbag, driver's
....!Air dam
1...!Air filter
5...!Amp, Monsoon
4...!Antenna, bracket, and motor if applicable
....!Ashtray & lighter
....!Blinker switch
2...!Bolt lengths, extra
....!Brake pedal pad
23..!Bumper, front reinforcement and brackets
21..!Bumper, rear reinforcement and brackets
34..!Carpet & Sound deadening
50..!Catback
15..!Cats
9...!Center console
....!Coating, under carpet
4...!Crossmember brace
....!Cruise control
10..!Dash
20..!Door panels
11..!EGR, air pump, & harware
....!Emblems
....!Fan, 1
....!Fan shroud
5...!Floormats
3...!Foglights and brackets
....FRA mod
....!Gas, Extra
2.5.!Glovebox
1...!Grill insert
4...!Hatch cover
2...!Hatch shocks
....!Headlights
....!Headliner
3...!Head unit
....!Head unit/AC console trim piece
8...!Heat sheilding
9...!Heater core
1...!Hood shocks
3...!Horn
3...!Inner fenderwells, plastic
....!Liscense plate brackets
....!Liscense plate(s)
....!Misc. junk in the car like keys, garage remote, change, owner's manual, etc.
1...!Owner's manual
3...!Panels, under steering wheel
5....Panhard rod brace, upper
....!Parking brake
....!Power brake booster
....!Parking brake handle
....!Power seat motor
11..!Power steering pump, pulley, idler pulley
....!Power window motors
1...!Rear view mirror
9...!Seatbelts (rears and passenger's)
34..!Seat, passenger's
19..!Seats, rear
3...!Sheetmetal, extra double walled
....!Shifter ****
5...!Side impact bars
35..!Spare tire and jack
7...!Speaker panels, hatch
5...!Speaker panels, rear passenger's
15..!Speakers
35..!Spoiler (Weight measured on a Pontiac)
....!Spring isolators
2...!Sun visors
14..!Swaybar and brackets, front
....!Taillight(s)
2...!T-Top holders
....!Under car tow points
1...!Washer fluid pump
9...!Windshield washer fluid
2...!Windshield wiper reservoir
3...!Wiper arms
3...!Wiper motor
....!Wiring, Excess
Wallet mods....
3...Airlid, aftermarket
3...Chromoly LCAs
3/9.Carbon fiber driveshaft
14..Chromoly A-arms
30.5Chromoly K-member
....Draglite wheels
....Drag slicks or street slicks
....Drilled axles
24..Dry cell battery
10..Electric water pump
....Fiberglass door skins
30..Fiberglass hood
....Fuel cell
18..'99+ fuel tank for '98 cars
....Headers
....Lexan glass
....Lightweight clothing
35..Lightweight brakes, front
....Lightweight brakes, rear
10..Lightweight flywheel
13..Lightweight springs and shocks
....Lightweight steering column
6...Lightweight steering wheel
10..Manual rack and pinion steering
....Plastic fuel tank, late model
....Powerglide, TH350, or M4 transmission
17/29.Racing seat
....Shortbelt mod
....Skinny front tires
15..Spool
20..TQ converter, small
....Underdrive pulleys
21.5!AC compressor
8.5.!AC condenser
....!AC fan motor
....!Air dam
1...!Air filter
5...!Amp, Monsoon
....!Blinker switch
50..!Catback
15..!Cats
9...!Center console
....!Cruise control
10..!Dash
20..!Door panels
....!Emblems
....!Fan, 1
....!Fan shroud
5...!Floormats
....FRA mod
....!Gas, Extra
2.5.!Glovebox
1...!Grill insert
4...!Hatch cover
2...!Hatch shocks
....!Headlights
....!Headliner
3...!Head unit
8...!Heat sheilding
9...!Heater core
1...!Hood shocks
3...!Horn
1...!Owner's manual
....!Parking brake
19..!Seats, rear
....!Shifter ****
15..!Speakers
2...!Sun visors
....!Taillight(s)
2...!T-Top holders
3...!Wiper arms
3...!Wiper motor
....!Wiring, Excess
Wallet mods....
3...Chromoly LCAs
14..Chromoly A-arms
....Draglite wheels
....Drilled axles
30..Fiberglass hood
....Fuel cell
....Headers
....Lexan glass
17/29.Racing seat
....Shortbelt mod
15..Spool
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
