how much slack in timing chain
Old Dec 15, 2007 | 03:01 PM
sn8ke eatr's Avatar
Exclamation how much slack in timing chain
i have a lt1 which is believe is un-rebuilt and has 181k miles. with the chain on, it seems like it has alot of slack in it,possibly too much. would you guys recommend changing it while the covers off? or do you think the slack is normal?
Old Dec 15, 2007 | 08:45 PM
maverickmk's Avatar
slack is bad replace it
Old Dec 15, 2007 | 08:55 PM
Stl94LT1's Avatar
When I replaced my stock timing chain at 20k miles, it had alot of slack. So, I'm assuming slack in the stock chain is normal. But with 181k miles, I would replace the chain while the timing cover is off.
Old Dec 15, 2007 | 09:35 PM
hvyss's Avatar
On me last build I decided to replace the chain on my LT4 extreme duty timing set due to I had about 1/4 inch of play. I reinstalled with a new chain and ended up with about a 1/4 play so some play is normal.
HVY SS
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
