How much power should this make
How much HP should this set up make and what do you think it would run in the 1/4 mi
1995 Formula-LT-1 6-speed everything has 12,000 mi on it
bored.30 over
All Keith Black Racing internals
RGR Stage II LT1 head porting job
Comp Extreme RPM Lt1 Custom 218/224.495/.503 112 LSA cam
BBK 52MM Throttle Body
SLP CAI
MAC headers
Magnaflow exhaust
Custom reprogram/computer tuning (by fastchips of Tulsa)
Eibach lowering kit
5.0 Pro shifter
STAR Spec Stage 1 clutch
Motive 373 gears
Mille Maglia 18's with Nitto 555's (255/45/18)
bored.30 over
SLP CAI
MAC headers
Magnaflow exhaust
Eibach lowering kit
5.0 Pro shifter
Motive 373 gears
I'll say around 410-415 RWHP (480ish at the flywheel) - a little more or less depending on tuning.
for the 1/4th mile. Probably around 12.1-12.2ish at around 113 MPH. You ET will depend on how good your 60 ft. time is w/ traction.
Calling the cam "small" is a relative statment. It's all gonna depend on how much drivability the driver is willing to loose. If its a daily driven car and you dont want to put up with a rough idle and lots of surge, then the cam choice really isnt that bad. If youre looking to maximize the power out of that set up, than yes the cam is a bit small.
I'd expect between 360-380rwhp out of it. If you could hook, I'd expect mid 12s out of it around 113mph.
With a larger cam, I bet you could get another 20rwhp out of it quite easily.
Yea I'd guess 350rwhp. That cam is not very large and even has less lift than the hotcam. And it looks like you won't have roller rockers or an electric water pump either. So ya 350-360rwhp. And for the 1/4 it all depends on 60ft time. People have gotten 11's with that much power, but the avererage joe might get a 12.5 or so... give or take a few tenths
F'n1996Z28SS
Aug 23, 2023 11:19 PM
