how much power can it hold???? stock tranny??????
Old Oct 22, 2004 | 11:35 PM
scottslt1z28's Avatar
i am going to spray a 150 wet shot on my stock car (plus......NGK iridium plugs, walbro 255 fuel pump)
will i have any issues with the tranny????
will anything break, if so what should i look for and try to prevent from happening???
Scott
Old Oct 22, 2004 | 11:50 PM
Seal's Avatar
Re: how much power can it hold???? stock tranny??????
i assume u have auto from ur gearing...
150 shot on a stock tranny will be pushing it i'd say
mine was slipping with 3psi which made like 80hp over... and n2o hits much harder... maybe use pills and have it shut off while it shifts...
Old Oct 23, 2004 | 03:19 AM
mybad........sorry i didnt say.............
yes i have a A4 and the kit that i am planning on getting has a window switch that starts spraying at 3000 rpms and cuts off at 5800 rpms.
Scott
Old Oct 23, 2004 | 07:37 AM
Brcarz28's Avatar
I have a stock A4 from a friend that used it on a supercharged camaro. All he did to it was put a shift kit in it, turned the pressure up. He was drag racing with it at the track, sith slicks(unkown power), and now that I own it I have put a single turbo kit (about 450HP) and have drag raced with it with no problems(street tires) and now am putting a twin turbo kit on it. I think that by putting a shift kit, and turning the pressure up, this definitly allowed for faster shifting. When the tranny shifts faster there is less time for the clutches to slip, and I am no tranny expert, but the less that the clutches are being used, the better. I will eventually be going to a TH400 w/trans brake, I dont trust the stock tranny that much, but it has held out so far to alot of beating.
Old Oct 23, 2004 | 08:04 AM
gmr speed's Avatar
My a4 took a crap when I was running 13.1"s....but everybodys will be different
Old Oct 23, 2004 | 12:57 PM
mebanditws6's Avatar
Keep the shifts under 6000 and put a Transgo in it with regular fluid and filter changes, and it'll hold, for a while.
Jason
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Noer
Feb 28, 2015 11:29 AM
siguy
Nov 27, 2014 10:07 AM
