How much more HP can I squeeze?
Old Feb 23, 2003 | 01:06 PM
95TA8280's Avatar
OK mods are below...I'm dyno'ing again soon and wondering what I'll pull. On my last dyno I only went to like 5600 RPMs and I guess my power band goes up with the new cam? So I'm gonna go up to 6200 or so, and I'm hoping for maybe an extra 5 HP? Also I'm adding the airfoil and my cutout will be open this time...how much should that give me? 10 or so for both? Also I'm hoping (I'm using those words a lot...) that I'm getting some knock and my KM will give me an extra 1 or 2....So could I pull around 320 or so?
Then my heads are getting off and I'm putting in bigger valves, P&P and Pcmforless....will all this be good for 40 HP or so? When all if said and done, is 360 a good estimate?
Old Feb 23, 2003 | 01:12 PM
qwick_trip's Avatar
the km does not add horsepower. it only retards timing and gives you horsepower back that you already had but lost because of engine noise. but if you are not geting false knock than your not going to gain anything.
drop top steve's Avatar
40 hp from a good head port (Lloyd was good #'s) and a pcm tune is possible. You may even get a bit more, depends on how good of tune you have now.
Old Feb 23, 2003 | 01:35 PM
95TA8280's Avatar
I know, but I was saying I might get it on the dyno....same thing as an exhaust....it doesn't *add* HP per say, juts frees up HP that the stock exhaust restricts you from getting.......
Old Feb 23, 2003 | 02:54 PM
96cam4ro's Avatar
With your setup, you should have at least 320 HP. And, yes, go all the way up to 6200. When I dynoed the first time, the guy stopped at 5400 and I only got 299.8 HP.
Old Feb 23, 2003 | 03:22 PM
95TA8280's Avatar
I know...my cutout was closed and I should've dyno'ed higher.....oh well, live and learn!
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
Hurin
Dec 13, 2014 07:38 PM
trax
Oct 5, 2004 10:52 PM
Robert95z
May 20, 2003 09:38 PM
KASR_Z28
N2O Tech
Mar 21, 2003 08:23 AM
