How much material do I need to take off the timing cover to fit a double roller???
Old Nov 8, 2003 | 12:23 PM
96 WS6's Avatar
I am about to go do this right now I just need some tips. What method did you use and how did you do it? I have a bunch of dremel bits that are fresh and ready to go. Thanks.
Old Nov 8, 2003 | 12:53 PM
FacelessZ's Avatar
Yea just use a dremel and start to slowly take some off...there isn't a "set" amount that you take off...it's going to depend on your chain and cover...
Old Nov 10, 2003 | 06:27 AM
IDOXLR8's Avatar
I did not have to grind away on my timing cover when I did the double roller chain. I would check to make sure it hits before you start grinding away at it.
Old Nov 10, 2003 | 07:55 AM
CANTONRACER's Avatar
Mine fit with no modifications whatsoever, other than the spacing for the CPS sensor.
Old Nov 10, 2003 | 11:56 AM
96 WS6's Avatar
I did check... what I did was put small dabs of antiseize on the rivots on the chain and wherever it showed up it meant the clearance was missing or very small so I just took some material off and its good to go now! The crank sprocket has a recess in the cover, the cam sprocket is what you need to worry about.
Old Nov 10, 2003 | 12:53 PM
Your gasket adds a little thickness.
Old Nov 10, 2003 | 01:17 PM
96 WS6's Avatar
I figured that too, I'd rather have a little bit of clearance than a pinhead sized clearance.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
Queens94z28
Dec 20, 2014 09:11 PM
97 RedSS
Jun 10, 2003 07:58 PM
