How much hp with rr
Old Apr 28, 2003 | 09:13 PM
zuluman13's Avatar
How much hp with rr
How much more hp do you get and how much would everything be new springs +w/e else I need?
Old Apr 28, 2003 | 09:23 PM
95TA8280's Avatar
There was a guy on here who gained like 26 HP from 1.6 RRs and a LT4 KM..........
Old Apr 28, 2003 | 09:41 PM
wicked_95z's Avatar
i dropped two tenths with 1.6's alone
Old Apr 28, 2003 | 09:49 PM
BPS's Avatar
BPS
seems like a lot for RR's - I suspect he was haveing a lot of KR before swapping the KM's
Old Apr 28, 2003 | 09:52 PM
lbrowne's Avatar
I was going to same the same, must of had quite a bit of knock retard.
I have Crane Gold 1.6 RRs here waiting to be installed and from all the researching I've done I think 16hp is the common gain. I think that was to the wheels.
Old Apr 28, 2003 | 09:55 PM
zuluman13's Avatar
Wow I guess they dont give you too much bang for the buck 250 for around 15 hp
Old Apr 28, 2003 | 10:01 PM
lbrowne's Avatar
to the wheels? i don't think thats too bad of a price for that hp.....
i got a good set used off of this board so i never paid full price for them.
Old Apr 28, 2003 | 10:29 PM
zuluman13's Avatar
Well I guess im considering that a cai is 25 for 200 Nitrous is 150 for 600 etc. I was just expecting more power from them. And actually how do they increase power if they just open and close the valves.
Old Apr 28, 2003 | 10:32 PM
lbrowne's Avatar
that is a question someone more knowledgeable will have to answer.
i'm going to guess it allows ffor the valve to stay open a tad bit longer allowing more air in/exhaust to escape... ok ok, i'm stopping before i make myself look too stunned in this category
Old Apr 28, 2003 | 10:40 PM
atljar's Avatar
Valve will not stay open longer, but will lift up higher in the same time span.
YOu know how everyone is always posting head flow numbers on here? Notice how as the lift numbers go up, so does the airflow? 1.6 rockers give you more lift, thus allowing more air to travel through the heads, even though the valves are open for the same amount of time.
Old Apr 28, 2003 | 10:41 PM
pennys58's Avatar
Dang, 15 to the wheels...I can't wait to get mine on. I've got the Crane Gold's too, would be nice if it were 15hp...
Old Apr 29, 2003 | 07:53 AM
zuluman13's Avatar
Thanks atljar
pennys58 ang, 15 to the wheels...I can't wait to get mine on. I've got the Crane Gold's too, would be nice if it were 15hp...
HUH!?!?!
Old Apr 29, 2003 | 08:02 AM
teke184's Avatar
"considering that a cai is 25 for 200 "
what cai are you using? i'd be impressed to see 15hp from one! typically it's more like 10hp.
you must actually beleive what the manufacturer tells you. iin that case, look into the tornado...it'll gain you about 20hp and 5% increasse in gas milage (j/k)
Old Apr 29, 2003 | 02:32 PM
zuluman13's Avatar
I also saw 15 as the "advertized" Gain for roller rockers anyway ill still probably get them i just always thought for some reason that they gave more hp
