how much HP do rockers add?
Stock springs are very borderline. Said to be good up to around .490 lift, I never found real limit numbers from GM though. With the stock cam and springs, valve lift is .447 & .458. With the 1.6RR, the lift increases to .477 & .488.
I decided to go with aftermarket ones just to be safe. I used the 611 springs from Combination Motorsports good up to .600 lift. I got the Comp Cams Pro Magnum 7/16" stud, so it would be stronger. Non-self aligning because they're better and not as noisy. Non-SA requires guideplates, I used GM ones.
They need adjusted, not that tough if you do it right. The rockers aren't too difficult to install, fairly simple, bolt on. But the springs, that's the tough PITA part, since you have to worry about dropping valves. I used my air compressor with a special fitting for the spark plug hole, did each cylinder... it's sort of time consuming.
Originally posted by Heatmaker
I'm limited to handtools and these are self aligning Rockers....Is there a tool that can be used to "drop the valves"?
Or fill the cylinder with rope, I've heard of that as well.
RUENUF
Mar 13, 2016 03:37 PM
