How much HP?????
Old Nov 9, 2007 | 09:21 PM
race u 2's Avatar
How much HP?????
how much HP do you guys think i'm cranking out read the sig & the heads are stock castings with a mild port & polish
Old Nov 9, 2007 | 10:29 PM
hektyk's Avatar
Hrmmmm, Just a guess but I would say 400-430?????
Old Nov 9, 2007 | 10:48 PM
speed_demon24's Avatar
350rwhp
Old Nov 11, 2007 | 04:53 PM
juiceTA's Avatar
more than stock i would hope
Old Nov 11, 2007 | 05:12 PM
3DFORMULA's Avatar
I may be way off, but, a 383 with 12:1 compression and mild ported heads, bigger injectors and throttle body, cam, tune, and headers. I would guess the 450hp area on the motor. Long tubes 1 3/4" headers would really improve the numbers over them short small tubes on that combo.
Old Nov 11, 2007 | 05:13 PM
96capricemgr's Avatar
Are those the heads from Golen?? Cam lift means little compared to duration numbers because duration dictates rpm and hp is torque at rpm.
His 440-480hp strokers are known to dyno way down in the 320-330rwhp range.
