How Much Horse Power
Old Dec 8, 2005 | 10:54 PM
hashimsaleh's Avatar
This question has been probably asked before, but its alot easier to get answers this way....
I have a 1995 z28 m6 and i was wondering with these mods listed below how much hp i should be around ?
ss Ram air Intake
Air foil
headers "ordering' y-pipe
Slp Exhaust
Hypertech programmer
Maf
Full tune up wires, plugs, fuel filter, opti spark
Old Dec 9, 2005 | 05:04 AM
HungryT/A's Avatar
Re: How Much Horse Power
I guess around 280 rwhp
Old Dec 9, 2005 | 06:28 AM
teke184's Avatar
they hypertech may actually be hindering your performance, as well as the maf...hard to say.
but i agree...280hp at the wheels
Old Dec 9, 2005 | 08:24 AM
what are some good extra mods to put me at 300 rwhp and not to costy
Old Dec 9, 2005 | 08:30 AM
HungryT/A's Avatar
Get some headers, and ditch the HPP, get a dyno tune!!! (AFR). That should put you over 300 rwhp easily!
Old Dec 9, 2005 | 11:25 AM
you think they hypertech is **** ? i've heard that before to whats a dyno tune ?
Old Dec 9, 2005 | 11:34 AM
87lt1rx7's Avatar
dyno tune is tuning your car on a dyno to get real time air/fuel ratios and tuning abilities that apply more to your car. I have seen HUGE gains on a dyno tune. well worth it
Old Dec 9, 2005 | 11:36 AM
BRIAN93Z28's Avatar
I think you guys are being too generous with the 280rwhp mark. Id say closer to 260-265 or so. First off the ram air intake from the SS hood really isnt all that great. Generally a regular CAI will work better. Also that MAF is really not that great of a mod for a basically stock LT1. And we dont even know what kind of headers you're getting. Sorry but I think if your running shorties you arent going to see too much over 260. If you get a good set of longtubes you MAY see 270-275. Just my .02, take it for what its worth.
Brian
Does it cost alot to do that ?
Old Dec 9, 2005 | 11:38 AM
BRIAN93Z28's Avatar
a good dyno tune will run you around $500 bux, but its well worth it.
Old Dec 9, 2005 | 11:41 AM
BUBBA's Avatar
Get rid of the Hypercrap. Get a Mail-order tune with Knock module. Don't mess with your MAF. Get some 1.6RRS with stronger springs.
Old Dec 9, 2005 | 11:42 AM
i actually from canada but right beside michagan i was wondering if any of you knew a dyno near by there ?
Old Dec 9, 2005 | 12:03 PM
BUBBA's Avatar
I would not bother with a dyno-tune. Just get a mail-order tune. If you just want to have it dynoed to see what your numbers are, that's ok, but I wouldn't waste my money on that. Furthermore, most dynos don't have the capability of tuning anyway. All they do is tell you what your putting to the wheels (which can vary from dyno to dyno). Mail-order tune will put you in the ball park with regard to proper A/F ratio, up your limit on your rpms to around 6300, and set your fans to go with a 160 Thermostat (which you should install in place of the stocker) JMHO
Old Dec 9, 2005 | 12:20 PM
BUBBA's Avatar
Even if you don't go with 1.6RRs, it won't hurt a bit to go with some stronger spings since a stock Lt1 seems to float the stock springs at higher RPMs robbing you of top end performance.
I just happen to have a set of REV springs that will easily accommodate your needs. They can use your stock retainers.
Old Dec 9, 2005 | 12:28 PM
i Didn't really want to go into my engine
