How much for engine rebuilt?
Old Sep 10, 2005 | 07:54 PM
alex-z28's Avatar
Also what are all the parts that have to be changed?
Old Sep 10, 2005 | 08:28 PM
Z95m6's Avatar
Re: How much for engine rebuilt?
You might want to state your goals, the amount of cash flow you have, what kind of streetability you want.
Old Sep 10, 2005 | 08:45 PM
mourningyou's Avatar
Since he didn't give any info, how about an experienced LT1 rebuilder letting us cheapskates all know what we really need to know: what is the minimum effort rebuild you could go through to support one of the commonly available heads and cam combo's (LE1,LE2,etc), and how much does it usually cost?
Old Sep 11, 2005 | 03:40 AM
alex-z28's Avatar
Ok here is some info on my car. It burns little bit of oil. I think that piston rings are worn out and so are my valve seals. I dont want to add anything performance wise since i might be selling it soon anyways and because of the high gas prices. So basiclly I just want to fix that. How much would that set me back.
Old Sep 11, 2005 | 01:02 PM
ZMAN Z28's Avatar
If you are going to re ring and bearing it, then cost's won't be that high. Provided you pull the engine and rebuild it yourself. It shouldn't cost anymore than 500-600 dollars to have the machine shop check the block/rod out the oil galleys, etc. Plus parts/gaskets etc. There are other more experienced guys that can give more insight.
ZMAN
MattFick
Feb 15, 2015 10:16 PM
dale3in98
Feb 14, 2015 12:18 PM
CaRParts102
Dec 6, 2014 08:45 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
