How much difference between 111lsa and 112lsa ???
Old Feb 17, 2007 | 07:55 PM
AZ2ENVY's Avatar
Is there a noticable difference in lope between a 111lsa and 112lsa
camshaft ? If so how much ? Thanks
Old Feb 17, 2007 | 10:15 PM
SStrokerAce's Avatar
Whatever 2 degs of overlap does to change your idle. If you have very little it's a big change if you have a lot of overlap it's a small change.
Bret
Old Feb 17, 2007 | 11:03 PM
AZ2ENVY's Avatar
Bret
K well how about the exact same camshaft 233/239 XE but just
one is 111lsa and the other 112lsa ?
Old Feb 18, 2007 | 01:31 AM
speed_demon24's Avatar
You're going from 12 to 14 degrees at .050, so it probably won't be that noticeable.
Old Feb 18, 2007 | 12:24 PM
Dam dude, just do a search on that cam it's different but not good.
Old Feb 18, 2007 | 12:26 PM
AZ2ENVY's Avatar
Ok i did search and didnt find the answer i am looking for . So whats
not good then ???
Old Feb 18, 2007 | 01:54 PM
It doesn't turn RPM to use the duration at hand due to the lobes being hard to control. Keep searching.
Bret
WobblySausage
Oct 7, 2015 02:44 PM
NewsBot
Sep 30, 2015 04:20 PM
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
