how much clearance do u lose with longtube (jet hot) headers
Old Oct 8, 2003 | 07:35 PM
glennxx1's Avatar
Old Oct 8, 2003 | 08:00 PM
CrippleFightin's Avatar
Couple inches., but you can still lower the car an inch or so with them. Stiffer suspension might help after you lower it too.
Old Oct 8, 2003 | 08:42 PM
glennxx1's Avatar
damn that sucks i was goin to slam it 2 inches,...so only go with 1 inch if im gettin the jet hot long tubes?...will i ever scrape my headers? i do not want to scrape what so ever i dont want any
holes in a set of 500$ headers
Old Oct 9, 2003 | 04:57 AM
revtime's Avatar
Its not usually the header you scrape its the Ypipe.
I have Hooker LTs and purple horny header mufflers and with Eibach drag lauch kit on it I scrape over speed bumps and extreme dips in the road at speed are no fun.
I would not be able to drive the car if I lowered it.
Old Oct 9, 2003 | 07:54 AM
93ZM6Tally's Avatar
I don't have my car lowered and have long tubes. I don't see how you could do both but I know people do it. I occasionally rub my header collector plate on speed bumps etc. I do have Koni SA's up front and I believe they actually lowered my front end a bit though. Sure do love the way camaro's look lowered though.
Old Oct 9, 2003 | 10:52 AM
glennxx1's Avatar
what would you be losing if u you went with shorty's or mid lengths instead of longtubes?
Old Oct 9, 2003 | 11:03 AM
revtime's Avatar
Nothing.
Old Oct 9, 2003 | 12:19 PM
93ZM6Tally's Avatar
Originally posted by revtime
Nothing.
I do think longtubes offer slightly better performance gains, especially low-end torque, but I think they are a smarter overall choice for street machines.
Old Oct 9, 2003 | 12:40 PM
Mystic97Z's Avatar
you actually loose low end torque w/ longtubes, but u gain more top end power.
Old Oct 9, 2003 | 01:22 PM
glennxx1's Avatar
well, this is what im wondering...how much larger would the numbers be if i went with longtubes than shortys if i had a big power adder, such as a twin intercooled procharger, and i was puttin 420 with shortys...would i have 440 or 450 w/ longtubes? or not that much better flow...thus only would be 5 or 10 hp difference
oh yeah, and with shortys do you lose clearance at all? if so, is it any where near as much as you lose with longtubes?
Old Oct 9, 2003 | 01:38 PM
Mystic97Z's Avatar
nah,u don't really loose ne w/ shorties
Old Oct 9, 2003 | 01:44 PM
ibanez6rg's Avatar
I just measured my Jet-Hots and came up with 5 inches at the pipe and 4 1/2 at the flange(stock height).
Old Oct 9, 2003 | 07:50 PM
revtime's Avatar
As far as clearance goes you won,t lose any with shortys.
When you get into big horsepower engines such as a stroker with a suprecharger you could see as much as 40 to 50 horse difference between shorty headers and Longtubes.
Old Oct 9, 2003 | 08:06 PM
klbjoc's Avatar
I have alwys assumed that because the primaries are longer on a longtube, you would actually gain more low end torque.
This backs up that thinking http://www.grapeaperacing.com/GrapeA...ustheaders.cfm
Old Oct 9, 2003 | 08:27 PM
JPSartre12's Avatar
My front end is about 1.5-2" lower than stock and my Hooker longtubes scrape on burms, steep driveways and even abrupt changes in road grade.
I have an Eibach launch kit and Hal's all around. If I see an unavoidable bump coming, I hit the gas and get the front end up.
I'm looking at raising it back up to stock height after the last racing day of the year.
