How much is an alternator?
Old Oct 6, 2003 | 06:33 PM
gb95zconv's Avatar
Mine is broken....the stud the wire bolts to is loose and it causes the check gauge light to flicker.
Old Oct 6, 2003 | 07:05 PM
LPEdave's Avatar
I got one from Jason Cromer a few months back, $135 + core...
Dave
Old Oct 6, 2003 | 07:53 PM
Re: How much is an alternator?
The stud can be repaired/replaced or tightened without buying a whole new alt.
Old Oct 6, 2003 | 07:55 PM
AustinZ28's Avatar
Got one the other day from AutoZone for around $85. It is exactly the same as my stock alternator ( same #s on the casting and all) and has a lifetime warranty . -----------> Brad
Old Oct 7, 2003 | 03:38 PM
badazzcamaro97's Avatar
I got one from Autozone for 99+core, this is a stock remanufactured one, they also have a new AC Delco for around 180+core.
Old Oct 7, 2003 | 03:59 PM
PumpkinKingZ28's Avatar
question about the sounds an alt. may make when its going out. does it make any??? my car when warming up makes like a belt noise, but the belts where the noise are coming from look new, i sprayed belt cleaner on it and didnt make a diference. the noise is coming from either the alt. or the belts connected to it. what do you guys think
Old Oct 7, 2003 | 04:11 PM
S.J.S.'s Avatar
try putting wate on the belt and see if the sound goes away. As for the alt. I had never heard it make noise. Usually it just doesn't charge the battery any more.
Old Oct 7, 2003 | 04:21 PM
jkipp84's Avatar
Mine was 'singing' for about 10 min or so after start up but charged just fine. I replaced it with a nifty powder coated 180amp from www.mralternator.com Not cheap compared to the Autozone one, but it's pretty nice.
Old Oct 7, 2003 | 04:22 PM
when i sprayed the belt with belt cleaner, the noise got worse. when any fluid leaks on to the belt the noise gets worse, maybe its the belt??
Old Oct 7, 2003 | 07:05 PM
gb95zconv's Avatar
Re: Re: How much is an alternator?
I was wondering about that.....looks like I have to take the alt apart to fix it....any tips....I sure would like to save $100 if I can.
Old Oct 8, 2003 | 06:03 PM
gb95zconv's Avatar
Well.....I took it apart and found the loose nut ....put a drop of loctite on it and tightened it back up. Put it back together and put it back on the car and hey, hey its good to go. Thanx Shoebox for pointing me in the right direction.
Old Oct 8, 2003 | 06:44 PM
It has happened to others, that's why I knew about it.
No need to spend $100 if you can spend nothing, eh? That's what fixing things yourself is all about!
Old Oct 8, 2003 | 07:08 PM
95 Z/28 LT1's Avatar
Super Moderator
Originally posted by ArcticYT95TA
Unfortunately, you are going to need that lifetime warranty if you got one like I had. It was replaced 3 times in the period of 6 months, the shortest one lasting 1 week.
That's just friggin' wrong.
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
Thirim
Jul 30, 2015 01:29 PM
