How Many, and Where are all the Grounds For the Engine?
Old Mar 26, 2003 | 02:36 PM
95 Z/28 LT1's Avatar
Super Moderator
I am trying to track down an ignition problem and I am going to look and see if my grounds to the engine from the frame are ok.
Where are the ground straps hooked up from the factory on the engine, and where do they all go?
I know there are a couple at the coil/head, but are there any more?
I will add some if need be, but I am hoping that there is just some corrosion at the ones that I have.
Any information or past experiences would be greatly appreciated.
Jacob
Old Mar 26, 2003 | 02:51 PM
Just off the top of my head:
-Main battery ground in front of the RH motor mount on the block
-braided ground strap and 3 other ground wires on the outside coil stud
-small black/wht ground wire coming out of the starter harness that attaches to the block
If you are wanting to trace all this stuff, you should think about getting at factory manual.
Old Mar 26, 2003 | 05:34 PM
Super Moderator
Thumbs up
Thanks for the reply. I will go over all the connections you mentioned and make sure they are clean. I have a feeling that the ones near the coil are causing me a little grief.
About the service manual, yeah, I know. I want to get one, but I don't want to take out a small loan to get it. Thanks again,
Jacob
Scottyboy
Feb 11, 2015 10:28 PM
Injuneer
Dec 15, 2014 09:36 AM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
