How many turns is .060 preload with 7/16 studs
Yes, because there are only 20 threads per inch (at least the ones I have) as opposed to 24 for the 3/8 studs.
7/16-20 studs: 1 turn is .050"
3/8-24 studs: 1 turn is .0416"
If the TPI is 24, one turn is going to be .0416" no matter what the diameter is.
(Sorry to jack your thread)This explains a lot. I set mine to a half turn past 0 lash and they felt loose. I gave no thought to the thread pitch being different. I guess this means mine are too loose. So I should have more like a full turn.
My friend with out of the box afr 225's and a small 224/230 114lsa cam in his LS1 made 428rwhp through a turbo 400 and unlocked convertor with Comp R's and stock preload on his LS1. And crane made the most power with their lifters with .060 preload on an LS1. I'm just trying to understand why you want them at 0 lash.
because on a iron block motor when I've dynoed them on the engine dyno I start at 2/3rds of a turn (.030" preload) then back them off to zero I always find HP usually 10hp.
I just set the preload up when the motor is hot and everything works fine from there. It seems loose but it's not hard at all to do and get correct.
Bret
Bret
