How many timing cover/front cover bolts are there
Old Feb 25, 2004 | 09:11 PM
TUFF LT1's Avatar
Just putting the timing cover back on and I have a couple of holes left. I have the three for the opti and two other holes left. One hole is on the left and one is on the right, both are above the lower most bolt on the cover. Are those holes just there for now reason? They seem to be blocked off??? Thanks
Old Feb 25, 2004 | 09:12 PM
NOMAD's Avatar
Cool
Those are probably the holes for the dowel pins. If they are raised up a bit from the actual flat portion of the timing cover, this is the case.
-Shannon
Old Feb 25, 2004 | 09:18 PM
TUFF LT1's Avatar
Hey thanks Nomad, I just took another look at them and shoved a meter lead into the holes to see if there was actually a hole there and NOPE! No place for a bolt to go?? I thought that maybe I were missing some bolts but looks like I'm not. And they are flush mounted and not raised. What are they there for?
Old Feb 25, 2004 | 09:27 PM
NOMAD's Avatar
I'm stupid, they are flush. Those 2 should be for the dowel pins that the timing cover sits on.
-Shannon
Old Feb 26, 2004 | 11:19 PM
TUFF LT1's Avatar
I'm stupid too i guess, for not looking which holes were for the dowel pins. I ended up taking the cover back off to find this out. To bad I didn't read your post before I did that. Oh well it was easy to take off. I just didn't want to have to break the seal you know. Thanks for the reply Nomad.
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
ddr698
Jan 9, 2015 10:05 AM
Queens94z28
Dec 20, 2014 09:11 PM
