How many miles is TOO many?
Old Apr 14, 2003 | 08:30 AM
Black6SpdTA's Avatar
I found two LT1's at a local yard for $300 and $335. they have 99k and 100k. i figure at this point they need a rebuild. would i need to? and are there any parts that where out within 100k on these motors? thanks
Corey
Old Apr 14, 2003 | 08:39 AM
Zrout's Avatar
LT1 is still just a SBC-like engine.
No need to rebuild it after 100k but since you didn't put those 100k on there you have no clue how it was treated so it makes sense to rebuild it. But as there are SBC's with 250k miles there are LT1's with 250k miles (and 79 new optisparks )
you could just take it apart , inspect , replace bearings , seals and gaskets.
It all depends on the condition of the engine.
Old Apr 14, 2003 | 08:40 AM
Zrout's Avatar
btw if you can hear the engines run and they run fine then no there is no need to but you also have to be prepared to pull the engine again when/if it breaks and then fix/rebuild it.
so IMHO it's not worth putting it in without atl east inspecting it after pulling off intake/heads/oil pan
Old Apr 14, 2003 | 08:52 AM
Dr.Mudge's Avatar
100k is great, I didn't even do heads/cam till beyond 100k. However if the engine was abused, then its a toss up that only testing will show.
Old Apr 14, 2003 | 08:56 AM
they're both from buick roadmasters so i doubt they were abused haha, but yea i think 300 bucks is a great deal. i have off of school this week so i might run up there and pick it up
Old Apr 14, 2003 | 08:59 AM
Dr.Mudge's Avatar
Where I live 100k miles is about 5 years of driving, and most cars last longer than that
Old Apr 14, 2003 | 09:01 AM
ok we just called about the motors. ones a '94 and the other '95. are there any differences between the two? thanks
Old Apr 14, 2003 | 09:10 AM
Dr.Mudge's Avatar
95 has a different timing cover/optispark setup, and is "better" if you are getting these components with them, otherwise the timing cover seperately is $40? 93-94 Optipuke is the worst of the bunch due to a nearly wide open back with virtually no seal.
Buick, so in theory an old person could have owned it, who may not have maintained it which = abuse your probably fine though, they are probably just wrecked cars eh?
Old Apr 14, 2003 | 01:51 PM
RENE95Z's Avatar
I would not necessarily say "old person" = abuse due to neglect. As a matter of fact, I know of such a person who has a Roadmaster and he takes care of that engine better than most people do their dogs. He helped me with my waterpump R&R. So, an LT-1 out of a Roadmaster would probably be in better shape than one out of a Camaro/Firebird/etc....
Old Apr 14, 2003 | 01:54 PM
mebanditws6's Avatar
The least you could do is pull the intake off and have a look at the top end and see how much sludge is there. If it's clean, then the motor is probably in pretty good shape and had regular oil changes. If not, then who knows. I'd still rather rebuild it no matter what as it's already out of a car.
Jason
mark0006
Feb 28, 2015 07:12 PM
jb4xx
Feb 2, 2015 10:00 PM
Jazsun
Dec 29, 2014 12:14 PM
