How many HP can LT1 handle?
if u go ahead mod the car.. how many HP can handle LT1s? 500 or 750 wrhp?
also can u guys compare with LS1 and LT1? how many horses LT1 can handle and howmany horses LS1 can handle...
Erdal
Erdal
Re: How many HP can LT1 handle?
What do you mean.. the block itself?
There's guys that have broken the 1000hp mark on LT1 blocks. How long they will last is beyond me, but that should give you an idea.
l meant, if u go ahead and mod stock LT1 how many Hp can you reach without have any trouble..
l know with LS1 you cant reach to 750rwhp with stock block.. l wonder how about with LT1..
Erdal
Erdal
From you initial post, I couldn't tell if your talking about motor or chassis. At this point I'm going to assume you mean the motor.
This is a very vague question. As Javier said, people have broken the 1000 HP mark on and LT1 block all day long.
I don't know how much power you can make by modding an LT1 without touching the motor. Intake, exhaust and programming will give you significant gains with no trouble to the motor. Are you consider Heads/Cam? Forced Induction? Nitrous?
You need to be a little more specific
Originally Posted by JustNO
He means how much HP stock block can handle. Untouched block.
I'm just not getting the question...
The stock rotating assembly can take a beating, but there's no magic #.. at this point the youngest LT1 is going to be 9 years old, and has probably seen some miles.
yeah l meant stock shortblock..
like you got a bone stock LT1 and you wanna put some bolts on stock motor to make it faster.. also how about chasis.. l heard that bone stock LT1 broke rear axle with sticky tires.. is that correct?
thanks
thanks
A stock LT1 can handle all the bolt-ons you can throw at it, and most do fine with a set of heads and cam as well.
The 82-02 7.625" 10 bolt is weak, no doubt, but A4 cars can usually last a bit longer with 'em. I have 300 or more passes on my stock 10 bolt, and it's still alive and kickin', with 1.6x 60' times.
yes the rear axle and rear end is weak, there is alot of talk about how weak they are, although i know 2 guys around here that run 1.4 60 on 250 hit off the line that dont break them...but it is the same rear end as the ls1, so they have no advantage there...a stock shortblock im assuming your gettin at rotating assembely...so we can add an aftermarket cam...i know weve broken 650+ hp...
thanks
thanks
The two documented failures of the LT1 PM connecting rods that I have seen both failed near the 600HP mark. GM rates the rods for 450HP. Anything substantially over 500 would seem to be pressing your luck.
The block itself is not the weak part..... I've personally seen an LT1 factory 4-bolt main block (with upgraded caps) stand up reliably to 1,125HP with no fill.
Erdal kardeş where are you from?
Istanbul.. but l am living in Atlanta, GA
how about you man? l cant believe l got a buddy in here on this forum...
l just saw your sig. and l bet noone can mess with you in istanbul because when l was there, all l was seeing was peugeot 106s
adin ne?
Erdal
