How to lube the new motor?
Old Oct 28, 2004 | 04:49 PM
Myxtreme1's Avatar
Anyone have any special way of doing this? I hve heard that since it's an LT1 it will be more difficult? Any advice will be very appreciated. Thanks!
Old Oct 28, 2004 | 04:50 PM
Alvin@pcmforless.com's Avatar
Re: How to lube the new motor?
Old distrubtor + Drill = Lubed motor.
It is my reccomendation you do this just like you would any other SBC> You will need the intake off though.
Old Oct 28, 2004 | 06:00 PM
97bowtie's Avatar
You can also get a fitting designed to be used in a drill that mates to the oil pump drive. You can probably order one from Summit.
Old Oct 28, 2004 | 06:07 PM
5.7LT1Formula's Avatar
i made a tool to lube the motor...but it sat on the stand for a day or so. Before firing it for the first time i pulled the coil wire off and bumped the keep about 6 times for a few seconds, put the coil wire back on and hit the key and it ran like a wet dream
BPS
9
Mar 5, 2015 10:51 PM
Hurin
Dec 13, 2014 07:38 PM
tds1213
Nov 27, 2014 12:55 PM
