how long to break in a motor?
Old Aug 21, 2005 | 09:08 PM
97SS0594's Avatar
my motor has aprox. 300 miles on it since the rebuild. the rebuild consisted of re ringing the pistons, new bearings all new sensors and such, we honed the cylinders too. but with this many miles shouldnt the rings be seated? every time i take it over 3000 it smokes like beat up honda. the only other thing i could think of is that there is something wrong with the heads as we didnt do anything to them. we just took them off the bad motor and stuck them on this motor, but they only had 60k on them roughly. is there something wrong or am i just prematurely freaking out?
Old Aug 21, 2005 | 10:12 PM
Re: how long to break in a motor?
300 miles might not be enough for the rings to seat, but I don't think you should be getting much smoke, either.
Old Aug 21, 2005 | 10:15 PM
1racerdude's Avatar
Give it some time.It depends on the rings and the install process.
Ya are to the mileage ya can go over 3000 and maybe tach it out once or twice for the next 200 miles if the oil pressure is OK.
Did ya get a tune? is the smoke fuel or oil?
Old Aug 21, 2005 | 11:50 PM
blackztpi's Avatar
usually 500 miles your good, unless you used rings that take longer to seat. them 1000 or so
Old Aug 22, 2005 | 01:13 AM
Black1995Z's Avatar
do you need to break in a used shortblock?
Old Aug 22, 2005 | 01:22 AM
regorih inHous.'s Avatar
sfsd
Old Aug 22, 2005 | 02:17 AM
97SS0594's Avatar
oh its deffinately burnin oil, on the woodward dream cruise i used 2 quarts of oil the whole day, but the car was running almost the whole day, went through almost 2 tanks of gas. my dad was saying something about one or more of the cylinders might be egged so it might take longer because when we rebuilt the motor we just honed it and didnt bore it any.
Old Aug 22, 2005 | 02:54 AM
Dave '97 Z28 M6's Avatar
I don't think you should be using 1L (quart) of oil for every tank of gas, unless you had an LS1
You say you're concerned about the heads... Are you getting any coolant in your oil, or vice versa?
Old Aug 22, 2005 | 04:40 AM
97SS0594's Avatar
ill know for sure this morning when i go and get my oil changed. but it was suggested to me that it might be the valve guide seals because i used to spray nitrous on the old motor. if this is the case how hard is it to change them?
Old Aug 22, 2005 | 05:29 PM
1racerdude's Avatar
To check the seals-- get the engine to normal temp,hold it at 2500 for 1 minute,then goose it pretty hard and let it come to idle then goose it again. If it smokes bad ya got bad seals.
Ya got to remove the springs to change them.
Did ya pour oil all over the rings when installing? Are they molly rings?
Old Aug 29, 2005 | 04:13 PM
92rslt1's Avatar
What size was your bore before th hone and what type of hone did you use. what rings?
transam_388
Mar 15, 2015 11:53 AM
cmyname1
Feb 19, 2015 08:38 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jan 5, 2015 07:14 PM
