How to install injectors???? (searched already)
Old May 11, 2005 | 02:59 PM
94heritageZ's Avatar
When putting the fuel rail back on do i need to lube up the rubber seals
on the injectors to go into the manifold ? Thanks in advance
Old May 11, 2005 | 03:04 PM
Deenasty's Avatar
Re: How to install injectors???? (searched already)
no, they should slide right in
Old May 11, 2005 | 03:27 PM
30696bird's Avatar
They will NOT slide right in. When you get new injectors they should come with some lube...........if buying used , use vasoline or some motor oil. It don't take much. If you try to slide them in without any lube you will rip some o-rings.
Old May 11, 2005 | 04:11 PM
Deenasty's Avatar
I bought brand new SVO 42's, they came with no lube, adn they slid right in. And the size of the o-rings on these puppies, there is no way in hell they are going to rip. But to eachman, their own..
AdsoYo
May 2, 2018 03:21 AM
RUENUF
Mar 13, 2016 03:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
Dec 1, 2014 08:08 AM
