How and how often????
Old Dec 11, 2003 | 10:26 AM
95patriotZ's Avatar
Hey guys, how do you change your fuel filter (location, how do i get to it?) and how often do most people change it? Kind of a stupid question but I would appreciate the help! Thanks
Old Dec 11, 2003 | 10:30 AM
thermwood1's Avatar
Filter is located on driver's side of car, about underneath the rear seat on the outside and is pretty close to the floorboard. It's in this general vicinity. Just jack it up and look around this area, you'll see it.
I would change it about every 15- 20,000 miles or so. Just a guess, i'm not sure what the manual calls for.
Old Dec 11, 2003 | 10:41 AM
95patriotZ's Avatar
Does anybody reccomend anything special, or should I just go to autozone and pick one up?
Old Dec 11, 2003 | 11:21 AM
Bastardcat's Avatar
I went with the AutoZone filter.
Old Dec 11, 2003 | 11:32 AM
thermwood1's Avatar
Same here with the filter.
Old Dec 11, 2003 | 12:45 PM
Taylor's Avatar
I run a wix filter from Napa it was about $12.
Old Dec 11, 2003 | 01:18 PM
LWillmann's Avatar
WOW 15,000-20,000 miles....
I've put 27,000 miles on my 1996 90,000 mile Formula and haven't changed the filter yet....
Guess I need to do that this weekend when I change the oil huh?
Anyone know if the filter is in the same place on an '01 V6? I'll change my wife's too while I'm at it.
Old Dec 11, 2003 | 02:21 PM
Joe Bellman's Avatar
I know my Haynes manual says to do it every 15,000 miles.
Make sure you take off the gas cap before you begin to remove the filter. That will relieve the pressure built up in the tank and lines. DO NOT turn the key on while the filter is off either. Wearing a set of goggles is a really good idea too.
Old Dec 11, 2003 | 02:24 PM
Removing the gas cap will relieve pressure in the tank, but not the lines. Relieve line pressure at the shrader valve on the fuel rail.
Old Dec 11, 2003 | 02:36 PM
LWillmann's Avatar
Are there any special tools required?
Old Dec 11, 2003 | 03:53 PM
jasons93z's Avatar
i just used some needle nose plyiers to push down the needle on the schrader valve.
Old Dec 11, 2003 | 11:41 PM
95patriotZ's Avatar
Where is the shrader vavle? I don't know what or where this is... Thanks in advance
Old Dec 11, 2003 | 11:48 PM
eagleknight97's Avatar
Thanks for the info guys. I think this might be done while im home on break from college.
Old Dec 12, 2003 | 12:09 AM
Here
Old Dec 12, 2003 | 12:14 AM
97WS6SCharged's Avatar
I change mine once a year on principle. It's $10 bucks, so what the heck.
