How hot do you operate?
Old Apr 14, 2008 | 07:58 PM
19z28camaro02's Avatar
Using your instrument cluster gauge, what is your estimate on how hot you operate on just a leisurely drive(no beating on it). I'm running about 210, used to run 185ish.
Old Apr 14, 2008 | 08:13 PM
mrmint69's Avatar
160 degree thermostat shows about 1/8 of the way up the gauge. Stays real steady weather cruising or racing.
Old Apr 14, 2008 | 08:32 PM
Craddock's Avatar
Mine stays dead on a quarter of the guage if I remember correctly. I'm so use to it staying at the same place I don't even remember where it sits at.
Old Apr 14, 2008 | 08:34 PM
Are you running a 160 or 180 stat?
Old Apr 14, 2008 | 10:07 PM
caldercay's Avatar
185* with a 180* thermostat.
Old Apr 14, 2008 | 10:18 PM
Bowtie4life's Avatar
anywhere tween 180 and 185 with a 180 stat, since my fan switch install, car never sees 210.
Old Apr 14, 2008 | 10:20 PM
Ironxcross's Avatar
I have the 160 stat, its just below the the first notch up from 160
Old Apr 14, 2008 | 10:23 PM
is your computer tuned for the 160 stat?
Old Apr 14, 2008 | 10:39 PM
You can run the 160° thermostat with no alteration to the computer.
Old Apr 14, 2008 | 10:52 PM
1996camaroSSclone's Avatar
with a fan switch and a 160 degree stat my street camaro never goes above the first notch up from 160 no matter how hot it gets.
Old Apr 14, 2008 | 11:07 PM
Red93Camaro's Avatar
I'm gonna need to get the 160* stat and the manual fan switch soon, My z28 gets up to 220* sometimes
Old Apr 14, 2008 | 11:16 PM
fan switch is a little pricey but well worth it. I ran at the track last year with it and was very inconsistent. After installing the switch my runs were all within one tenth of a second.
Old Apr 14, 2008 | 11:39 PM
No need to worry. The stock fans are programmed to come on at 226°, so you are not in any danger.
Old Apr 14, 2008 | 11:57 PM
I would like my engine cooler, If you know what I'm sayin
Old Apr 15, 2008 | 08:34 AM
Z-RATED94's Avatar
175 to 185 with a 160 thermostat and the fans re-programed.
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 02:44 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
damnyankee36
Sep 9, 2015 07:06 PM
