How the hell do I get the crank pulley hub off? :(
Old Jul 5, 2005 | 10:40 AM
Black1995Z's Avatar
Exclamation How the hell do I get the crank pulley hub off? :(
Wow, I thought it was going to slide out.. had to buy a puller and the bolts it came with were too short. After running around all day I finally founds some bolts that fit. I got the pulley off; but the little hub behind it wont come off. How do I remove it?
If you all need pics let me know, I can take some.
Old Jul 5, 2005 | 11:14 AM
sbs's Avatar
sbs
Re: How the hell do I get the crank pulley hub off? :(
There's a special tool:
Balancer Hub Removal
Kent-Moore tool J-39046 is required when removing or installing the balancer hub from the crankshaft on 1992-97 L99/LT1/LT4 engines. The tool is available from Sallee Chevrolet or directly from Kent-Moore at:
Kent-Moore Automotive Group
Spx Corporation
29784 Little Mack
Roseville, MI 48066-2298
1-800-345-2233/FAX 313-578-7375
Monday through Friday 8:00 a.m. to 8:00 p.m. EST
I think people do get them off without that tool, but it's a PITA.
A steering wheel puller works if it's out of the car.
Old Jul 5, 2005 | 11:15 AM
Remove the center hub bolt going into the crankshaft.
If you are using a conventional balancer (crows foot) puller, you must insert something into the hole where the center bolt was, so the center shaft of the puller will have something to push against. It needs to be something that is very hard and will not bend (some people have used socket extensions - be careful, though). It also must stick out far enough for the puller to work. You don't want to harm the threads of the crankshaft.
The specific puller for the LT1 uses a hardened threaded adapter that screws into the crank.
After you get that set up, it is just like pulling any normal balancer.
HectorM52
Jun 23, 2016 08:42 PM
Boss002
Jan 20, 2016 12:17 PM
whitehooptie
Jul 12, 2015 06:10 PM
Chevyguy358
Jan 28, 2015 08:04 PM
