How hard is it to replace the waterpump?
Old Jul 21, 2004 | 12:23 PM
LT1Noob's Avatar
Just wondering what to expect. I can do basic stuff, like brake jobs, oil changes, trans filter ect. How hard is it, and how much do LT1 waterpumps typically cost? TIA.
Also, is an electric waterpump an option? My car is daily driven in the summer in city traffic.
Old Jul 21, 2004 | 12:28 PM
944v8inDFW's Avatar
Re: How hard is it to replace the waterpump?
Water pump is pretty easy. 6 bolts an 1 electrical connection. A rebuilt pump is in the $50 range and a new is in the $150 range. Pretty easy on the lt1. Or fourse you got heater hose and rad. hoses as well. You should replace the thermostat at the same time. Electrical water pump IMO is a gamble on a street car. If it fails you are jacked like 17 switches. With the OG pump it may leak a bit but at least it will get you home!
Old Jul 21, 2004 | 12:49 PM
LT1Noob's Avatar
don't even know if it IS the water pump. About a week ago, I got the 'low coolant; light. I checked the overflow tank, and the level was fine. I threw some Dexvool in, just in case, and the light went off.
Now it comes on intermittently. I've been noticing small paper-plate s-zed puddles of water on the ground after the car is parked, and is ISN'T from the a/c, since I rarely use it.
Someone was saying that it could be blown had-gasket
There isn't any smoke at start up, the car runs fine....but the temp starts to creep up in heavy traffic (faster than it used to) At cruise, I can drive for an long periods of time, and won't go past 160 degrees
Old Jul 21, 2004 | 12:57 PM
944v8inDFW's Avatar
A water pump wont make the car get hot unless of course it is leaking. Only time to replace them is if they are leaking or the bearings go bad. Sounds like a thermostat to me.
Old Jul 21, 2004 | 01:35 PM
95BlackTA's Avatar
You do know how to bleed the air out of your coolant system after you add more coolant right?
And before you replace the pump, take the car for a drive, get it hot, and then jack it up and get under it...dont burn yourself, but really look good at all of the hoses. The LT1 is soo damn packed in there its hard to see them all, so use a flashlight. Also check the two heater hoses that go into the firewall on the passenger side.
Old Jul 21, 2004 | 01:54 PM
RENE95Z's Avatar
Do you sometimes feel like the power steering is going out on you? This is an indication that the WP is leaking on the serpentine belt and causing the belt to slip. Is there coolant on top of the throttle body? This would be slung from the belt if the WP was leaking. These are two pretty quick ways to tell if the WP is taking a dump. I would also suggest bleeding the air out of your system.
Old Jul 21, 2004 | 02:10 PM
moparman's Avatar
Be sure to check the plastic parts of the radiator. It the plastic is cracked, it may only leak under pressure. The low coolant light is a known problem. The sensor is located on the radiator by the battery. I just unplugged the one on my car.
Old Jul 21, 2004 | 08:26 PM
Bud M's Avatar
http://www.streetillusionsracing.com.../opti/opti.htm
It's a guide for replacing the optispark, but you can just go as far as the water pump.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
pologreen97z
Dec 2, 2014 10:42 AM
teedoff59
Aug 8, 2002 01:36 AM
