How hard is to pull heads out?
Old Mar 16, 2003 | 05:50 PM
alex-z28's Avatar
I want to know is it hard to take off exhoust manifolds and then put them back on.
Old Mar 16, 2003 | 06:02 PM
Ken95Z28's Avatar
Stock exhaust manifold?
I would replace them with some headers than putting back on the stock set.
Old Mar 16, 2003 | 06:15 PM
Achilles97's Avatar
Do you just want to take off the exhaust manifolds? Or take off the heads?
The exhaust manifolds is not hard, basically just unbolt it. The hard thing is getting it off of the ypipe, you'll need some liquid nails...
Old Mar 16, 2003 | 07:22 PM
alex-z28's Avatar
I want to take the heads out. I have to change the valve seals and i was thinking of getting new springs and 1.6 rockers. I know that I can do that with out taking heads out but I don't have air compressor to keep valves from droping in cylinder.
Old Mar 16, 2003 | 07:30 PM
Shankels94TA's Avatar
Is it really worth taking off the intake manifold and the heads just for new springs and rockers? You will have to buy new gaskets for the heads, intake manifold, and exhaust manifold. All that stuff isn't cheap. Borrow a compressor from someone... that would be cheaper even if you rented one. With the air compressor all you have to do is take off the alternator and valve covers to get to everything. Just trying to save you some agrevation.
Old Mar 16, 2003 | 07:39 PM
gb95zconv's Avatar
Just bring the piston to the top in each cylinder one at a time (you can actually do 2 at a time if you know the pattern) and do the springs and rocker.
Old Mar 16, 2003 | 07:44 PM
gb95zconv's Avatar
Another trick is to stuff a piece of cotton rope into the cylinder filling the empty space.
Old Mar 16, 2003 | 07:47 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
beat me to it-
i say just save up for headers, they you justify doing it
HectorM52
Jul 30, 2017 11:46 AM
Chris Anderson
Jan 27, 2015 08:30 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
CobraEatr
Jul 29, 2002 11:46 AM
