How hard is installing new injectors?
Old Aug 4, 2003 | 11:47 AM
bad1LEz's Avatar
I'm slowly upgrading and freshening up parts as I go on my mistreated 1LE that I have owned for 1 1/2 years. I was thinking replacing the injectors would be something that could make a difference and something that was easy that even I could do. Injectors on now look stock. How hard is it to put new ones in? Should I stay with the same lb or go up to next larger size while I doing it?
Old Aug 4, 2003 | 11:54 AM
GetaZforgetGT's Avatar
With your present mods I wouldn't worry about upgrading the injectors.
As long as they are working now I wouldn't replace them just for the sake of replacing them. Injectors can last for a very long time.
The overall process isn't hard but I would pick up a repair manual from your local Advanced Auto or Autozone just so you have the info infront of you and you can follow it step by step.
Old Aug 4, 2003 | 12:08 PM
bad1LEz's Avatar
Thanks man. I have a manual, just didn't read up on injectors yet. I guess they are still working ok. I run injector cleaner through them about once a year, along with Seafoam once a year.
Finally someone in central PA - I'm up around Hershey. I've had some bad luck finding a good shop to take care of my Z. Any place you might recommend? I'll need some Y pipe/cat conv./catback exhaust work done this fall or next spring.
thanks
HectorM52
Jul 30, 2017 11:46 AM
armedtrigger
Feb 24, 2015 08:30 PM
Alex Barnes
Jan 24, 2015 10:21 PM
SpidermanForever
Aug 30, 2002 02:13 AM
