how hard is it to hit 10s
Old Feb 10, 2006 | 07:19 PM
redington's Avatar
ok guys how hard is it to hit 10s in an lt1 what needs to be done. does it need to be 355 383 396 can it be done w/ a 350?
could a le3 package and a 200 shot put it in the 10s? if the motor was built to handle the n20?
Old Feb 10, 2006 | 07:43 PM
redington's Avatar
Re: how hard is it to hit 10s
i was just trying to see what it would take to put a killing on some people around here. weather it be n20 FI what ever. I was just looking for way to hit 10s.
Old Feb 10, 2006 | 07:46 PM
neil350's Avatar
On gas its very possible to make the power for it even on a stock bottom end.
Old Feb 10, 2006 | 08:06 PM
ABA383's Avatar
Quickshotkimber is in the 10s n/a with a stock bottom end and a big Joe Overton cam with E.B. Porting doing the heads. I'll hopefully be close n/a with my next few mods for this season on pump gas (crossing fingers)...
--Alan
Old Feb 10, 2006 | 08:17 PM
Josh'95Z28conv's Avatar
Ive been told by a reputable person that a good 355 with an LE3 package can hit 10's NA. Sure, thats with great traction and all, but its possible
Old Feb 10, 2006 | 10:15 PM
amean94ta's Avatar
well i am trying to get ther n/a look at my sig
Old Feb 10, 2006 | 10:39 PM
LT1 EXPRESS's Avatar
I did it with stock ported heads small cam rockers bolt ons and 2 stages of nos on a stock bottom end ph yeah I forgot to mention I melted that motor down street racing a mustang actually we both melted aor motors down
Old Feb 10, 2006 | 10:52 PM
Honda Hunter's Avatar
Doesnt it take like upper 400's to 500 RWHP to get a LT1 car into the 10's?
Old Feb 10, 2006 | 10:57 PM
Ur not there yet????how fast have u been?
Old Feb 10, 2006 | 11:07 PM
Jameslt1TA's Avatar
Originally Posted by Shackleford
With a 200 shot, yes. But, would you want to run 10's ONLY when you spray? You'll get to the 10's much easier with forced induction.
I would have to dissagree with you about fi being easier. n2o is cheap and your stock bottom end can handle it for awhile. an fi needs a really good bottom end. Not to mention a blower or turbo kit will cost alot more than an n2o kit.
A le2/3 kit and a 150 shot of n2o with a good stall/clutch, tranny, rear end, good suspension and complementing bolts ons combined with really low da and good traction should net you a high 10...provided everything is working to its full potential.
Old Feb 10, 2006 | 11:13 PM
95Bird's Avatar
no...well..yes on a bad setup car..but on a good setup car you can get there wtih much less.
Old Feb 10, 2006 | 11:45 PM
Jeremy95TA's Avatar
I personally have never been 10's, but I have a lot of friends who have. Keep this in mind. Going 10's isn't that terribly difficult. What is difficult is building a motor that will go 10's more than once.
Old Feb 11, 2006 | 12:03 AM
1racerdude's Avatar
There in lies the problem
Old Feb 11, 2006 | 12:30 AM
Purplemaroz28's Avatar
I ahve to disagree with you on nitrouse being cheap. If it's done right nitrouse is expensive, almost as much as a FI setup. (please take in mind this is my opnion) If you do it correctly (wich is the only way i would recomend) then a nitrouse system gets very expensive. What i mean by right is a reliable setup, that will also keep your engine alive. A cheap nitrouse system might seem like a good idea and yes it will let you hit 10s, im not arguing that but it wont let u keep hitting 10s, after a while your lack of prepartion is going to catch up to you. My suggestion would be ( keep in mind this is my opnion, i have never run 10s in my life nor sat in one that has, i have just been reading on here so i know there are more experianced out there, so take my advice if you want.)
a 12 bolt w/ 4.11 or lower ($2000-3000), if its a auto a high stall if its a stick then a strong clutch($400-700), subframe connectors($200) 15X10 wheels in rear 15X6 front with slicks on the 10's ($1000-2000) drag springs/shocks ($500), rear suspension pieces(panhard rods, lower control arms, and tourque arm) ( $1000) Then start worrying about hp, a 355 can do it, but build it to handle what you want, a 383 gets better (if done right). If you want FI have it built to handle it, if you want N/A then build a high compression engine, ($4000-7000), Boltons ( Longtubes, intake, injectors, electric water pump, exhaust maybe even a cutout, tb) ($1500) have it dyno tuned ($200-600) Then Fi (nitrous, supercharger, turbo) ($2000-5000) ( if you want it) Then some other small things, such as relocate battery, remove interior, and to be safe, and hold the chassis together better, a roll cage would be a good idea( $1000). Im sure 10's is achievable with out all these things but in my opnion i would want something done right then half assed, so this is the way i would build a 10 second car. ( since i have a lack of money i wont for a while). So there you go. Hope someone reads it so this wasnt a total waste
Old Feb 11, 2006 | 12:45 AM
1racerdude's Avatar
Really can't see how ya are going to build a 10 second engine N/A for a 3500lb car for 4-7000 dollars... More like 15-18,000 dollars for parts. This don't include the wheels tires and chassis and 9" and drive shaft.Built several for customers and have never done it for less,but have spent more. $7,000 won't buy the heads,intake,injectors, cam and valve train.
