How hard is it to bend the rear axle?
Old 01-18-2004, 10:56 AM
eyeoutthere's Avatar
Unhappy How hard is it to bend the rear axle?
A few days ago, I put my TA into a ditch.
We pulled it out by wrapping a tow strap around the rear axle (right by the drivers side spring mount).
Now it starts to shake at speeds above 50mph. The whole car shakes and it doesn’t feel like it is coming through the steering wheel... so I think it is coming from the rear.
There is no snow packed in the wheels that I can see.
1.) What are the chances that I bent the axle pulling it out of the ditch?
2.) Is there any way to check the geometry myself?
3.) If I take it to an alignment place, what are they going to be able to tell me? (i.o.w. what are they going to be able the narrow it down to? A wheel, the axle, a mount...)
Thanks for any input…
-Jason
eyeoutthere is offline
Old 01-18-2004, 11:25 AM
Pandamonkey's Avatar
Re: How hard is it to bend the rear axle?
1) Pretty good I'd say..........
2) No, you'd be better off taking it to a shop.
That sucks man.
Pandamonkey is offline
Old 01-18-2004, 11:37 AM
Wouldn’t it more likely be a suspension piece rather than the rear its self?
I can understand the rear bending if I was pulling it from the pumpkin… but from where I was pulling it, all the force would be on the suspension.
-Jason
Old 01-18-2004, 11:43 AM
OldSStroker's Avatar
I doubt pulling it out or even going into the ditch bent the housing.
My guess is either bent wheel or bent axle shaft flange or both.
That should be easy to check.
OldSStroker is offline
Old 01-18-2004, 12:37 PM
Hyperspeed97z28's Avatar
I got a 3.42 10 bolt if you need one. all you'd have to do is swap your brakes over. I'm in albany, ny
PM me if your interested....
Keith
Hyperspeed97z28 is offline
Old 01-18-2004, 12:55 PM
1995greenTA's Avatar
i put my TA in a ditch about a month ago being stupid and only two tires were left on the ground we pulled it out with a 4x4 and a tow strap around the axle, no problems since then
1995greenTA is offline
Old 01-18-2004, 02:26 PM
desertwind's Avatar
Yeah the camaro got side swiped and it didnt bend the axle, it ripped the rear wheel with the rear braking assembly still lugnutted to the wheel right off the rear end like a clean sliced tomato..........Get my point........
MIke
desertwind is offline
QuickSilver02
04-07-2015 11:12 AM
Chet1185
02-04-2015 09:51 PM
4586
01-03-2015 07:22 PM
nodnarb481
Middle Atlantic
01-01-2015 11:43 PM
rockync7
01-01-2015 05:10 AM
Quick Reply: How hard is it to bend the rear axle?
