how to get marsh underdrive pulley off?
Old Apr 22, 2004 | 02:02 AM
KillinFormula's Avatar
My opti blew and i need to get that pos off... i took off the harmonic balancer but the marsh underdrive pully is like freakin tight as hell and wont budge... do i need a pulley remover to take it off?
thank you
braden
Old Apr 22, 2004 | 04:47 AM
BiGGinZ's Avatar
You could use a puller. I tried that when putting my pulley on to take the balancer off. It didn't work so I just put a metal bar I had laying around behind it and rested it on the sway bar and pushed it with my foot kind of wedging it off and it loosend up and came off.
Old Apr 22, 2004 | 05:02 AM
I have no sway bar in the front ne more so that kinda rules out that option, but i am in wonder as to how a puller works...
does it cling to the sides of the pully and a shaft that is threaded with a bolt on the end get tightened and pushes against the hub to pull it off? am i close to thinking how it works?
Old Apr 22, 2004 | 08:57 AM
ttt
Old Apr 22, 2004 | 02:24 PM
BiGGinZ's Avatar
http://shbox.com/1/pull_pulley.jpg
I believe you would still need to use this kind of puller and just put it around the pulley. Because if you bolt into the pulley you are pulling the whole hub off.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
Rde Bandit
Mar 21, 2015 10:17 PM
