how to get the 3 front bolts out to remove the catalytic on a 93 Z28 ?
Ok I was going to gut my cat on my car, got the bottom bolt out (on the front of the cat, 3 bolt flange) but there was no way I could get to the upper ones. Is there a trick to doing this?
Originally posted by madwolf
3 bolt flange? You mean on the y-pipe or the catalytic? The stock catalytic only has 2 bolts on the rear flange. There is no front flange unless you're talking about the y-pipe, which has 2.
mine has a 3 bolt flange on the front. I have AS&M headers... so it might be different than stock? But its a 3 bolt flange on the y-pipe, connected to a 3 bolt flange on the front of the cat. Still has the 2 bolt flange setup on the back of the cat
Mikes 1994 z28
Nov 25, 2014 02:00 PM
Jul 4, 2005 05:00 PM
