how to fix a backfire?
Re: how to fix a backfire?
is there any type of hesitation or does it only do it during a shift at WOT? more than likely you have a "leak" in your ingnition stemming from the header installation. what type of plug wires are you running? make sure that they arent arching out on the headers. wait until night time and look under the hood with the car running. you will probably see a plug wire arching out.
plug wire arching out from the opti? o and this happened right after the pcm tune, not after headers, it didnt do this popping sound, and i have a high flow cat... and also i feel a little loss of power...
i got otvc, where can i get a single piece from if i got it from thunderracing, if i got mine burnt? can there be any other things? how can one melted one cause a popping sound? and are there any other thoughts?
thanks
thanks
WobblySausage
Oct 7, 2015 02:44 PM
tommalcolm
Sep 11, 2015 03:39 PM
